I would like to thank Chris Hightower for bringing this possible (now proven) fix to my attention in this thread. To date, I believe that I am the only one to do this and report back to the community. It is VERY easy to do and takes all of 15 minutes.
Tools Needed:
1 8mm 1/4 socket & rachet
2 hammers or 1 hammer and 1 block of wood
1 set of lockable plyers
1 tire iron
1 small screw driver
1 jack
1 jack stand
Part Needed: 1S7Z-7M101-KA (Turbine Speed Sensor) - $15 at FordPartsOnline.com
Step 1) Pop the hood and disconnect the battery's negative cable.
Step 2) Loosen the lug nuts on the driver's side front tire, jack it up and support it safely.
Step 3) Remove the tire and locate the sensor just below the brake line holder on the fender well lip.
Step 4) Disconnect the sensor harness from the sensor.
Step 5) Remove the retaining bolt, then using a pair of locking plyers, pull the old sensor out. It works best to rotate the plyers while pulling directly out towards you.
Step 6) Install the new sensor:
a) Insert new sensor.
b) Using either a block of wood or another hammer handle, place the object flush on the back of the sensor, and then gently tap the object with a hammer to push the new sensor into the sensor hole.
c) Insert the new bolt and torque it snug (specific torque unknown).
Step 7) Reconnect the sensor harness.
Step 8) Remount the tire and snug the bolts.
Step 9) Lower the car.
Step 10) Reconnect the battery's negative cable.
My Review: This took literally 10-12 minutes ... VERY easy to do. After doing so, I took the car out for a 30 mile drive and aside from fixing the 1-2 "Bang" shift, it smoothed out all shifting. If my impression changes, I will report it here.
LinkBack URL
About LinkBacks
